Automotive electricity
How is the diagram of lights, crosses, brakes simple and practical ,,,
#elroller22
Know the electrical installation, how to make your crossing explain? How to combine crossing and brake with esplique diodes? hello thanks friends I just want to learn a little electroauto if you could help me ... regards
hugodesalta
hugodesalta
2.450
If what you want is to learn this beautiful trade, I do not think this is the right place, you should look for some technical or arts and crafts school, and if possible, parallel to that, use an electricity workshop as an assistant, to Acquire practice, since these two things go hand in hand, if you have practice and lack technical foundations, you will stumble upon problems that you will not be able to solve.
Ennio Montenegro.
Reference is usually made to the circuit of a particular car. Your search on the internet, put brake lights or virage lights etc or automobile electrical diagram and select images. I share a scheme that I raised some time ago, of a question that they wanted me to use the same lights for the brake and the virage. https://www.yoreparo.com/vehiculos/electricidad/preguntas/5748848/luz-de-giro-y-freno-juntos Basic schemes of virage and brake. If in doubt, comment here
#elroller22
ok but you don't have diagrams ...? brake, crosses,
