Automotive electricity
Fiat cronos 2018
mostro13
Hello gentlemen of me I repair, I want to ask you something about a problem that I have in the car of the brand and model described above, the battery was discharged very fast, in fact I took it to the agency for that, I want to get the doubt out, I They said it was discharging because the ground cable of the battery negative was loose and that made the charge come down quickly and that the alternator also failed and in fact the computer therefore failed, they say they tested it on the route and now it works fine, they screamed the whole system saying that everything is ok, the question is: it may actually affect the operation of the alternator and not charge properly because the cable is loose. I turn to this forum because I know they will get me out of this doubt for sure. Thank you very much, and greetings to all.
jorge lopezangel
If the dough is loose it brings all kinds of disorders, use it quietly, regards.
mostro13
Thank you teacher, I still don't have the unit, I'm still at the agency for your check-up, as soon as I have it back I tell you how it works, regards.
