Automotive electricity
fiat duna 1.3 mpi model 2000 starts only 4 or 5 seconds
willytransistor
Hello friends, I have a 1.3 mpi fiat dune to which I made a change of hoops, timing belt, crankshaft and cylinder cover with valve seats. The issue is that now the car starts but only takes four or five seconds and stops as if it cut the power. The car only goes on gas does not have the gasoline pump
Jjn
Jjn
Jjn
5.128
Do you have an alarm?
BIN2013
BIN2013
2.689
Friend, check if you have a brown wire that goes from the CNG key to the spark plug wires or to the coil!
willytransistor
Thank you friend, I inform you that I already found that the failures were a cable that goes to the computer cut the broken spark plugs and several air leaks in the hoses. the issue is that the car is only gas and now when it is heated it accelerates what can it be?
