What you are measuring is normal.
The solenoid has 2 coils. One of current in series with the starter that is yel that produces the coupling and the other of tension that is between the terminal that comes from the key and ground. It is useful when the engine starts keep the coupling retained.
If you look at the image, you will realize that the measure you do is normal.
