Automotive electricity
There is no spark in spark plugs
Luisito252015
hace 6 años
hace 6 años
I have a 6 cylinder chevrolet distributor, which I am testing with a battery, but when turning the shaft only a spark from spark plug wire connectors comes out. What can be the cause of the failure, the pickup coil, the rotor, the coil or the cover. Very grateful to anyone who can help me
linogonzalez
linogonzalez
2.331
hace 6 años
I say is the cover if it were a coil it would not come out in any
Ennio Montenegro.
hace 6 años
Check inside the lid. I would not be spinning the rotor, to distribute the spark.
Luisito252015
hace 6 años
Thank you for the contributions today I will implement your recommendations and inform you.
Luisito252015
hace 6 años
I inform you that the problem was the cover. Thank you all
BIN2013
BIN2013
2.689
hace 6 años
hace 6 años
Friend, see if the axle fins that pass through the sensor are not too far away, the axis may be crooked!
Luisito252015
hace 6 años
Let me check to see the position of the fins and I will inform you
