Automotive electricity
Low battery
Gabriel Irlanda
hace 6 años
hace 6 años
Good, the car did not start me today, for some reason the alarm rang for about 30 seconds or more and it is seen that I finished using the battery, I measured it with the tester and it gives me 9.2V. It is possible if I start the car with a wiring from another car that can start mine and that using it a few minutes I can recharge the battery or that charge is very low and already died, that is, I can not recover more and I must change it. It is 12V - 70Ah for a C200 MB.
Germàn LB Service
hace 6 años
You can make a bridge from vehicle to vehicle, once you start you have to check if the alternator is charging between 13.8 and 14.4 volts and you should check if the battery accumulates the charge. If you charge correctly and when you start the voltage drops to 9 or less it is a warning that you have to change the battery.
Germàn LB Service
hace 6 años
If the battery is very low it is advisable to charge it with an external charger and then put it to charge in the vehicle so as not to make the alternator suffer so much.
mario r ventura
hace 6 años
hace 6 años
if you can bridge with another vehicle, and it will recover charge with the car running, if you can test if it loads you in motion if load has to vary between 13 and 14v if it goes down it is the alternator that is not charging you, and if the alternator is doing well but after leaving it stopped for a moment it does not start it is the battery that has already completed its cycle to see if the alternator charges and you do not have a tester, disconnect the positive terminal of the battery with the car running, if it stops it is because it does not charge, if it stays for a while it is because it charges well
Gabriel Irlanda
hace 6 años
sorry for the delay, it was just the dead battery, nor did I want to waste my brother's time to make the bridge and directly bought a new battery, I changed it and ready, to perfection.
