Automotive electricity
a problem with the alarm of the jetta a4 mod 2000
moge18
moge18
5
hace 6 años
hace 6 años
the problem is that the alarm is activated .. the vehicle is a 2000 a4 jetta ... the alarm is activated at the time of putting the insurance and it is deactivated when removed .. the problem is that it is not deactivated, it is still set ... I don't have the control, I only have it with a chip, with it I deactivated it but it had a fault that I no longer want to deactivate ...
José Manuel Calderon Tina
hace 6 años
hace 6 años
Check some pins that have in the union of the door and the carnage unsafe one broke down so when you act the alarm sounds like a pin is wrong the censor sends as if a door was open Czech. And let me know... Another could be the alarm relay that is in a fuse box. regards
