If they blink normally and after a while there are days left, it is probably the Ripper that is damaged.
Sorry, I changed all the words hahaha ... are fixed ... And instead of ripper, Ripper.
Hello! Thanks for answering, would the ripper be the same as the flasher? or relay? regards!
Can you tell me where the beacon flasher is located in the Renault 12 model 89? Thank you!
On the left side of what the steering column would be, your model should have two flashers, one for beacons and one for turns.
Thank you for responding, I apologize for leaving the subject unanswered, the truth is that I was somewhat busy, and the other day I put the beacons, but that problem did not stop blinking and remain on constantly, so no I paid more attention, but it is obvious that if he does that it is because something is not right, tomorrow I will put a picture of what I think is the flasher, to see if you tell me if it is that or not, thanks for helping me and sorry for the delay!
