Automotive electricity
Excite vehicle alternator
MARIO FABRIS
hace 6 años
hace 6 años
We have an alternator that is required to excite it with a light bulb but we want to do it by placing a resistor ... If someone has done that job what resistance value can be placed ..........
hugodesalta
hugodesalta
2.450
hace 6 años
3 or 4 watt lamp (the porthole should be with isolated legs). It will work just like a vehicle. When you connect the batteries to charge them, voltage will reach one leg of the lamp, and by the regulator and the rotor it will make mass and it will turn on, when it begins to charge that mass will become positive and it will turn off the lamp, like a car.
hugodesalta
hugodesalta
2.450
hace 6 años
hace 6 años
And so that you are going to place a resistor ?, If you do not want to put the indicator lamp, which apart informs you when the alternator stops charging or when the belt breaks, put a cable with contact current directly.
MARIO FABRIS
hace 6 años
What happens is an equipment that adapted an alternator to maintain the batteries ... It is not a vehicle
hugodesalta
hugodesalta
2.450
hace 6 años
From the positive of the batteries take out a cable, and place a button so that the other end reaches the excitation of the alternator, when they run the engine that moves the alternator, press that button once and it is already excited. And if you want to make it more automatic, instead of the button it puts a warning light, an ox eye with a
JulioCesarTorres
hace 6 años
hace 6 años
Place a 50 ohm 3 or 5 wats resistor in series with a diode, whose anode goes to the start point and the cathode goes to the resistance that ends at the alternator's excitation point.
