Automotive electricity
Bsi exit to fog
Leandro Gomez
hace 6 años
hace 6 años
Hi, does anyone know what is the connector on the peugeot 208 active bsi fog?
Chuca
Chuca
394
hace 6 años
hace 6 años
Hi mate, why do you want to know what departures they are? In the bsi you will only find the signal that goes out to the motor fuse box (psf) in this box if you locate the outputs. If your car does not have fog lights and you want to install them, you only have to wire from PSF if your vehicle does not carry the installation and activate the front fog lamp option that will disconnect any doubts or questions by commenting a greeting
Leandro Gomez
hace 6 años
Hi master ... I just thought I was out of there ... from the fuse box I decided to use the bsm box as I locate the cables to do the wiring from there
Leandro Gomez
hace 6 años
Hello my friend, I'm waiting for your help
Chuca
Chuca
394
hace 6 años
There are two options or that you buy the wiring from the source and avoid complications or that the car already comes preinstalled, look behind the front bumper if you see a connector on the left side if your car does not bring that preinstalled as it already explains you it must be configured by Diagnostic tool for this to work but for many cables it will be of no use to know where the wiring is going to need more data of the car frame number but it is impossible there are many versions of assemblies I hope you solve your doubts
Leandro Gomez
hace 6 años
Amigo is a peugeot 208 active 1.5 2016 chassis hb0001335 opr 143957 ... and in the bumper I did not find the wiring ... I do know that I have to activate by diagnosis ... but nobody wants to do the wiring there may be that this is the wired up to the fuse box in the engine .... as I noticed in the manul it has a fuse that could be of the F16 15 amp fog says that it is fog ... I leave my number 3743496526
Chuca
Chuca
394
hace 6 años
Hello, you should not put personal numbers or emails in the forums, read the regulations so that your account is not banned, rectify or delete that statement, I am also from Spain due to the time change it is quite difficult for us to talk
Chuca
Chuca
394
hace 6 años
In any case, you would have to buy to wire suitable terminals and cables in peugeot it will be cheaper and faster what you tell me to catch original installation and zero complications or in some scrapping to locate one that mounts and do not complicate the terminals you need adequate tools to press them well and also to install them inside your card you will also need some types of screwdrivers to open the connectors is not as easy as you see you need several things buy installation and do not complicate yourself more I hope you clarify your doubts a greeting
Leandro Gomez
hace 6 años
Well what happens that peugeot only sells the wiring for the headlights ... and missing the wiring that joins them say that that does not sell it ... I mean that it would still be missing the wiring that joins them ... let's say the wiring that comes from inside the vehicle
Chuca
Chuca
394
hace 6 años
You are wrong if it is sold by reference of spare parts and brings all the necessary connections and wiring for the installation as well as a sticker to put on the lights control with the drawing of front fog lamp work in peugeot I know what I am talking about in spare parts you will see as if you are selling greetings
Chuca
Chuca
394
hace 6 años
And the wiring as I indicated at the beginning comes out of the box motor fuses (psf) not inside the car (bsi)
Leandro Gomez
hace 6 años
Well I found out in peugeot and they sell me the wiring, let's say they are connected in the headlights with a whip that I should connect there where I decided in the psf box ... and how do I identify which cable is in the psf box?
Leandro Gomez
hace 6 años
Could you make me a diagram of the psf box where they are connected?
Leandro Gomez
hace 6 años
hace 6 años
So I can connect it with the wiring ... if I identify the wiring of the psf box the rest I get
Leandro Gomez
hace 6 años
Let's say I have the wiring ahead as ago to identify in the psf box so I can splice it
Chuca
Chuca
394
hace 6 años
If you have the wiring ahead you have it, it is very easy to connect to the configurable connector and ready, if the connector is not in the kit, it indicates in which fixa to introduce the cables everything is specified in the companion kit
Leandro Gomez
hace 6 años
Well friend, I will consult peugeot and see how the wiring comes ... if you don't say in the quit, tell me where I connect it?
Chuca
Chuca
394
hace 6 años
Ok mate greetings
Leandro Gomez
hace 6 años
I already went to look at the peugeot spare parts house and that wiring does not bring any indication ... it comes only the tab to connect in the two headlights and a tab at its end to connect the cable that comes out of the psf box .. .but only that branch sells ... I mean I'm still complicated not knowing which splice
Chuca
Chuca
394
hace 6 años
Companion there is a kit for the after-sales installation that brings the wiring that goes from bsi and the fog lights also anyway I will see personally what reference is because you are only seeing the wiring with headlight connector and what I tell you is for After-sales installation for vehicles that do not carry as I told you work in peugeot and I miss it many times this is so since the 206 year 2000 from there for all models there is the after sales kit
Chuca
Chuca
394
hace 6 años
I would be happy to tell you what connector it is and what number of track but you have no means to open the connectors or terminals of that type to install the cables your easiest option is the one that I mentioned after sales kit
Leandro Gomez
hace 6 años
A good layers in Argentina I did not know that because I went to several peugeot and they only have the cables in front ... not the complete one as you indicate it to me ... and the kits that are as you say come with a separate connection with key
Chuca
Chuca
394
hace 6 años
Leandro Gomez
hace 6 años
If it is not too much trouble and you can indicate or make a diagram I would appreciate it since I need those lights to travel ...
Leandro Gomez
hace 6 años
The kit that I get is the one that is for an individual connection they sell me with relay and separate key
Chuca
Chuca
394
hace 6 años
And what terminals are you going to use if they only sell it in spare parts and only technicians in electronics and electricity have access to the references?
Chuca
Chuca
394
hace 6 años
But have you gone to a peugeot dealership?
Leandro Gomez
hace 6 años
If I went to peugeot to several workshops ... they want to change the 2000 cv and do everything they ask me for more than 40,000 pesos
Chuca
Chuca
394
hace 6 años
Because from what you just told me that is from outside of origin in peugeot the kit that they sell you does not bring any relay comes its wiring to put it in its connector the wiring of the bumper aloa fog and the fog lights also comes everything necessary for your installation and it would only be necessary to activate it by means of a diagnostic tool, nothing unusual for individual installations if your purpose is to save yourself by buying it and doing it yourself is another matter
Chuca
Chuca
394
hace 6 años
Nor does the commutator change, I do not tell you either in a dealership they sell you in spare parts the necessary after-sales kit so easy in other workshops they will do it through another type but the ideal and easy is kit
Chuca
Chuca
394
hace 6 años
In having time I look at you what reference you have to look for
Leandro Gomez
hace 6 años
Of course I told them that it is activated by diagnosis ... and they tell me that there is no need to change the switch ... and I went to several ... noc layers is a habibada noc ... and about the kit I also asked him and They tell me that they don't sell like this ... just as I mentioned layers in Argentina with Mercosur cars, so be it
Leandro Gomez
hace 6 años
According to the pin 58 and 59 from bsi in connector 60v nr they should leave or enter
Leandro Gomez
hace 6 años
Ic05 10 nr says ant right 2 and 4 and left 9 and 10
Chuca
Chuca
394
hace 6 años
Since bsi nothing comes out of the box psf
Chuca
Chuca
394
hace 6 años
From there the signal of activation of fog lights comes out through the communication cables to the psf for those same cables activates more things long dipped lights and several other things are signals not voltages
Chuca
Chuca
394
hace 6 años
Tell me the last 8 numbers of the frame and I indicate
Leandro Gomez
hace 6 años
Hb001335
Leandro Gomez
hace 6 años
Then, if or if you have to have the branch up to or to psf
Chuca
Chuca
394
hace 6 años
desdd bsi until psf is all wired you just need psf to headlights and activate by diagnosis
Leandro Gomez
hace 6 años
Good
Chuca
Chuca
394
hace 6 años
But as I told you not to LOAD it after sales kit and if you tell me that they have told you that in the dealership look for another one that does not seem to be very professional or understand much about the subject
Leandro Gomez
hace 6 años
The cable of the headlights I have only the one that leaves the psf
Leandro Gomez
hace 6 años
Do you need any more information about the car?
Leandro Gomez
hace 6 años
Could you shrink where I connect them?
Leandro Gomez
hace 6 años
Hi friend, good morning
Leandro Gomez
hace 6 años
Friend
Leandro Gomez
hace 6 años
These?
Leandro Gomez
hace 6 años
Friend
