Automotive electricity
connected ignition module siemens re 261 renault 19
lu7mas
lu7mas
2
hace 6 años
hace 6 años
Hello, I would like to know if someone has or knows where to get the connection for this ignition module. since I can't find it anywhere, thank you.
Jjn
Jjn
Jjn
5.128
hace 6 años
hace 6 años
Is it for a 19 1.7, carburetor? These are the minimum connections for the engine to run. The connector A is coupled to where arrow # 11 points. The connector that does not appear here is the C, which is 3 pins and is connected at the other end is to modify the advance of the ignition at low temperatures of the refrigerant and in the activation time of the electric fan.
lu7mas
lu7mas
2
hace 6 años
AFTERNOON I SAW THIS MESSAGE, BUT THANK YOU.
