Good afternoon everyone, I was set on fire part of the engine for breaking the gasoline hose. buy the new sensors, the sensor card of the three-pin cam shaft that comes from the ecu has pink-black-and green wires, which one goes with the mass of the ecu? Of course, thank you very much to everyone
I have no information about the colors, but this is the branch connector that comes from the ECU, and the cables reach these pins:
N 130 - Pin 53 (Sensor Mass, shared with TPS)
S 130 - Pin 16 (Positive, shared with TPS)
V 130 - Pin 11 (Signal)
