Automotive electricity
Measuring battery charge with motor working
mario17farias
hace 6 años
hace 6 años
Good to all, as I always come to you with my problems and I learn by the way, well I have a toyota corona 77 that had the mechanical regulator burned, I sent him to put an electronic one, the guy put one of three terminals of the brand Gauss. Well the issue is that before putting the regulator, he took out the alternator, disassembled it and put some diodes 5408 to each diode of the stator, the reason why, I do not know, also, according to the data sheet of diodes 5408, these hold up to 5 amps nothing more, when the gauss regulator data sheet says it handles 55 amps and it is a type B circuit, the regulator charges the battery but there are times that it does not, I got tired of telling the guy who made me to go see, then I decided to do it myself, I have electronic knowledge and I already did of many data about it to be able to check it, well when I start the engine I measure the voltage with the multimeter but it gives me an incorrect reading, that is to say it goes crazy and gives me a varied or itermit reading does not stay in the 14V as it should be, who could check to know what's wrong? I already checked the altermandor diode bridge also those added by this person and all measure correctly, I changed the coals too. Any idea what may be causing this problem? OBS tested the multimeter in another car and it works fine.
Germàn LB Service
hace 6 años
Laion is right, or you measure away from the engine or extend the tester's cables to the battery to get away from the vehicle.
The diodes put by the electrician must be auxiliary for the pilot light of the board to work, this is necessary to excite the alternator and start charging.
When it is in contact that light turns on, when the vehicle is started it goes out, that tells you that the alternator is charging.
laion2016
hace 6 años
hace 6 años
Among the "possible" causes to this problem could be due to magnetic fields of AT, for example, old cables, IGN coil, damaged capacitor filter, etc., if you try to measure voltage at another point in the car away from the engine compartment, it should mark as you want
mario17farias
hace 6 años
Thank you for responding, now that I remember, the mechanical regulator brought a cable in one of its terminals with the symbol "IG" I suppose that ignition, that cable was connected by what appears to be a capacitor covered by a sheet that in turn goes to Earth, could that capacitor be responsible for filtering the current from the diode bridge?
Ennio Montenegro.
hace 6 años
hace 6 años
The regulation with electromechanical box, are different from the electronic regulation. The first regulates with the positive and the second with the negative. In the electronic regulation, the charge warning light is used to start charging and when the alternator is delivering the voltage, the same voltage reaches the light on both pins, so it goes out. The diodes that you put are for the field excitation circuit, so they are of less current. When measuring the voltage at the terminals of the battery, it should be scraped on them so that a correct reading. The other thing is to do it with the lights on, to know how much delivery with the maximum consumption of accessories. It is difficult to give a single probable cause, since it is not the original equipment. Possible causes such as measurement error should be ruled out. You must measure the minimum and maximum values delivered with the engine idling and at about 3000 rpm. In addition with the highest idle consumption and also at 3000 rpm. Comment results.
