Automotive electricity
front alzacristal in Corsican does not work
pablodeuruguay
hace 6 años
hace 6 años
Chevrolet Corsa Sedan. The right front alzacristal does not work, that is the engine if it works, then I opened the panel and in the linga there is a piece that revolves around the alzacristal, but after using them a few times, that piece is loosened, from what I saw It would have some broken rivet in the mechanism that goes inside the door, and that is why the piece that looks like a gear when it receives the force of the motor, leaves the alzacristal. I would like to know if something similar happened to someone, and how do I solve it? Thank you.
Canario2016
hace 6 años
Change the glass boost or try to rivet the old one again.
pablodeuruguay
hace 6 años
I will change the rivets and comment again if I could solve it. Thank you
pablodeuruguay
hace 6 años
I changed the rivets and that was the problem, it was working perfect. Thanks for the help !!
Canario2016
hace 6 años
Then punctuate me!
Canario2016
hace 6 años
hace 6 años
Change the glass boost or [b] try to rivet the old one again.;) [/B]
