Automotive electricity
Over battery charge
alenobtecnico
hace 6 años
hace 6 años
Good people are over charging me the car battery I wanted to know if it is the alternator regulator that is failing,?, Thanks
alenobtecnico
hace 6 años
solved
JOSE MIGUEL SIRGO PASCUAL
hace 6 años
hace 6 años
Effectively. The regulator is responsible for controlling the output voltage of the alternator.
alenobtecnico
hace 6 años
Thank you genius I imagined, it catches my attention because it is new I changed it a few months ago is that yes or yes or could it be something else? I also have the old test with that and I will know whether or not it is the regulator, thanks
hace 6 años
The regulator is responsible for measuring the voltage of the battery and depending on its voltage it has to give more or less current to the coil of the alternator field so that it increases the magnetism or decreases it and that way the alternator generates more current when the system electric demand more energy
hace 6 años
It is a very effective method that exerts a good control of the correite without any element being in series with the passage of the current only the rectifying diodes are in series.
hace 6 años
It is as if we had a dynamo that had a magnet with variable magnetic field.
MJGTSAS
MJGTSAS
4.613
hace 6 años
Before changing the regulator, check the battery status, if it is reaching the end of its useful life, it does not hold and charge.
hace 6 años
MJGTSA what you say makes no sense. The consultant has indicated that the battery is OVERLOADING.
alenobtecnico
hace 6 años
change regulator and issue fixed
alenobtecnico
hace 6 años
change regulator for a new one and continue with the same battery overload fault measures more than 14.2
hace 6 años
That can only be that the mass of the regulator is deficient.
alenobtecnico
hace 6 años
hace 6 años
the battery is new so change the regulator
alenobtecnico
hace 6 años
Will it be a platelet problem, some diode or something?
