first check if you have a positive voltage when you turn on the key, check the negative pulse when starting if you don't have a negative pulse, check the crankshaft sensor
I have the diagram to piss you off but I can't piss you off after a while I send you the link to download it when my pc allows me the lionk
I already checked the diagram I do not have voltage on the green cable with orange that feeds the coil module if I have negative pulses but the 12 volts are missing but I do not find that relay provides these 12 volts I do not have the cover of the relay positions I would appreciate if you tell me what it is
https://1drv.ms/b/s!AkDpIKcd6H2Lli1BVg-7v28nb9S1
The relay is the automatic design SHUT DOWN RELAY when the switch is opened. This relay is activated for 2 seconds, once it goes over the currents, it reaches the relay in the first diagram, the currents and fuses that feed them are fused. feed this relay and find itself in that fuse and relay holder
