Automotive electricity
Close up crystal circuit
Nicolas Baldino
hace 6 años
hace 6 años
Good people, the query is the following, I bought a van with glass lifts in the 4 doors, but in the rear I don't have the swich to go up or down, there are only the cables, if I press the keys of the driver that gives me to go down or Uploading the butts does not happen, someone told me that this happens because the circuit is not closed because the cables are without the key, then, I ask, I can join the cables that would go to the back key to close the circuit and get it from the keys Do the rear windows work on the driver's side? If yes, how do I do it? Thank you
electrostorm
electrostorm
2.622
hace 6 años
you need the diagram of the system of elebadores and if it can get you with the master switchs that is the one that is on the driver's side if it is good there you can raise and lower the rear
jogresmo31
hace 6 años
hace 6 años
good night brother the glass elevator system of the main command (pilot door) works in series with the other swich if you disconnect a swich of course it will not raise or lower the glass you did not specify what van is but I can help you you have to have a current tester you must first disassemble the doors and identify the two cables that go to the motor, the other two cables are the inverters that come from the main control, just jumper the motor cable with the inverter cable of the control in each cable if you have inverted that When you go down, go up and vice versa, just invert the cables. Note, if you replace the swich, you must remove the jumpers first. I hope it helps you
Nicolas Baldino
hace 6 años
Hello, perfect explanation of yours, the truck is a 2002 Chevrolet S10, I'm going to try this and tell me if I can solve it, thank you very much
jogresmo31
hace 6 años
You're welcome, brother, we are here to help you remember to comment positively
Nicolas Baldino
hace 6 años
It worked perfectly, you are a genius, thank you very much
jogresmo31
hace 6 años
You're welcome brother, we're here to help remember to always value
