hace 6 años
hello the pump is inside the gasoline tanke, you should feed the pump with 12v directly with the help of someone and start it, if you turn on, then you change the pump, also check that when you get in touch this 12v coming to the pump of course, but It is the relay or a fuse. Comment, value, Greetings!
