Automotive electricity
liquid battery formula
cris-shet
cris-shet
118
hace 6 años
hace 6 años
hello dear friends I comment I have a totally dry battery I know that it carries sulfuric acid and distilled water but I don't know the percentage that it takes of water and acid if you know you can tell me
edyedy87
edyedy87
581
hace 6 años
hace 6 años
Hello, when the battery is discharged, the acid is converted into water by the reaction of lead with sulfur, water and lead sulfate are generated, when the water dries, it evaporates if you put only distilled water and recharge the sulfur, it mixes again with the water which is transformed into sulfuric acid, the acid level is measured with an acid meter. Now if your battery has already dried up, it is likely that it is no longer of adequate performance
cris-shet
cris-shet
118
hace 6 años
yes but what I do not comment is that it is not a car battery is an amplifier rechargeable gel battery is completely dry is square like that of cars and I think I have to add acid the issue is the percentage between water and acid I filled it with distilled water but I do not know how to generate the acid and also charge it with the car battery charger does not generate the acid for that?
celentauro
celentauro
3.878
hace 6 años
Every battery has a time of use, no matter how much you charge acid and distilled water, it doesn't even go back. How long is that battery?
edyedy87
edyedy87
581
hace 6 años
Celentauro is right it is difficult to revive a battery, and even if it is not a car it is the same as it is lead-acid.
See if you remove the plugs you can see in the background some stones is the sulfate generated, those stones must be undone which is delayed and complicated, the battery has a sheets that become thin over time and become unusable or short-circuited, in the spare parts American rias for cars sell you the acid already prepared test with that one and measure with multimeter the voltage of each cell but see if they are short or if they do not take charge
cris-shet
cris-shet
118
hace 6 años
thank you friends i'm going to buy a new one for my client is
