Automotive electricity
Megane phase 2 front lamp
Carpintería.sergio.
hace 6 años
hace 6 años
Hello people of the group I come with an intrigue! I have to change the low lamp and turn of a Renault megane 2. Year 2009 From what I saw you have to disassemble the entire tube to get the optics, I could change the low from inside the fender for a cover that I see! But for the turn I think it's complicated! Is there any other way or is by dearming the front of the car! I consult it since I never did it! Thank you for contributing your knowledge.
hugodesalta
hugodesalta
2.450
hace 6 años
hace 6 años
It is not necessary to disassemble the front to change the lamps, lift the hood and look well. If you don't take it, put pictures and tell you what to do.
Carpintería.sergio.
hace 6 años
Well I saw everything very compressed from the hood the battery is sticky ... but good tomorrow I take photos thanks
Carpintería.sergio.
hace 6 años
Hugo thanks for the contribution there I could take out the lamps so if the vision is zero I hope to put the lamp insurance! Now if what I could not do is take the lamp out of the turn, is it like inside the optics any tips?
hugodesalta
hugodesalta
2.450
hace 6 años
From the engine, behind the turn lamp, you should see two legs of the lamp holder with the connection, turn and pull back and the turn lamp holder has to come out.
Carpintería.sergio.
hace 6 años
Hi, just the turn lamp is the one on the driver side, I turn and shoot but I get a little and it hits me against a rifle box that is next to the battery and doesn't want to go out anymore
hugodesalta
hugodesalta
2.450
hace 6 años
It has to go out ... loosen the fuse box a little or take out the battery, get out without taking anything else.
