Automotive electricity
I don't know where the TSURU 98 battery cable goes
SosaA
SosaA
15
hace 6 años
hace 6 años
Hello how are you. This question might sound somewhat funny but today I maintained my departure from the tsuru 98 and once I finished it I mounted it again the problem is that I realize that the negative cable that comes from the battery is loose. I do not know where it is screwed, it is assumed that this cable goes directly to the engine block but I do not know where. Please help!
Germàn LB Service
hace 6 años
Dear, generally the negative is connected near the starter motor. You also have to have a negative battery to chassis or engine to chassis.
J. E. T
J. E. T
810
hace 6 años
hace 6 años
Hello, the earth or battery mass is screwed to the largest screw that stops the engine running In other words you can put the ground wire to any of the screws that stop the march just make sure it is tight and grease free By the way, I don't know the suru but some take a cable from the car chassis to the biggest terminal of ls matcha Salu2 Annex reference image ignores the ammeter
