Automotive electricity
FIAT 147 horn
musicaghf
hace 6 años
hace 6 años
Good Morning. I have a Fiat VIVACE mod. 94 and the following problem with the horn: when the car is running and, mainly, moving the horn works perfectly. Once I turn off the engine, the horn stops "screaming" and only emits a sound similar to "glock". I already changed fuses, I tweaked the spiers behind the steering wheel (on the controls) and accommodated them, since it didn't even work before. Greetings and I appreciate the help in advance.
Ennio Montenegro.
hace 6 años
Some have a tone adjustment screw. Try to release it a little.
musicaghf
hace 6 años
Where are you ?, please ..
Ennio Montenegro.
hace 6 años
hace 6 años
Check if you have an adjustment screw on the back like the picture. https://www-comofuncionaunauto-com.cdn.ampproject.org/v/s/www.comofuncionaunauto.com/accesorios/no-funciona-la-bocina-del-auto.amp?amp_js_v=a2&amp_gsa=1&usqp=mq331AQCCAE% 3D # aoh = 15477586024743 & amp_ct = 1547758639552 & referrer = https% 3A% 2F% 2Fwww.google.com & amp_tf =% 20% 251% 24s & ampshare = https% 3A% 2F% 2Fwww.comofuncionaunauto.com% 2Faccesorios% 2 -Fno-works of the car
musicaghf
hace 6 años
It was just that. Now it's perfect. I just loosened it a little.
Thank you very much for your help. I send you a hug
Ennio Montenegro.
hace 6 años
We are here to share knowledge and experiences.
