Automotive electricity
Selenoid activating egr valve ford bronco 1995 v8 sinc
albert1
albert1
14
hace 6 años
hace 6 años
Hello dear friend of the Yoreparo community. I have a question about how the selenoid works that activates the egr valve since I see the selenoid. It has the vacuum hose in continuity .. bone if aspirated by the vacuum hose that comes from the manifold. air is sucked in and it shouldn't be because the selenoid must be locked as long as no power is supplied .. it is straightforward in a few words
albert1
albert1
14
hace 6 años
I have read that after 70 degrees and the vehicle in motion the pcm activates the selenoid so that it lets empty into the egr valve ....
Now my question is if that signal that comes out of the pcm is negative or positive ...
albert1
albert1
14
hace 6 años
Someone who has an explanatory manual has close to the different components and sensors so please provide me with reading and instruction. where explain how to try each one. And its measurements
celentauro
celentauro
3.878
hace 6 años
hace 6 años
A video to understand how it works.
albert1
albert1
14
hace 6 años
Thank you
