Automotive electricity
connect peugeot 205 temperature clock
totoxxxx
hace 6 años
hace 6 años
Hello people my query is I have the temperature clock now the positive of both the clock and the light goes to 5 amperes if I did not read badly, how do I locate that amperage in the rifle? Is the fuse 5 but where do I connect the wires for the positive?
hugodesalta
hugodesalta
2.450
hace 6 años
hace 6 años
What you should indicate, and what you can opt for are VOLTS, the amperes are the ones that will circulate according to the power of the instrument or light you are using.
