Dear, as José Ortiz says, the rectifier bridge is missing, it seems that it exploded, it may be due to a large short circuit or polarity inversion.
They usually come with a value of 25 or 35 amps. It has 4 terminals, 1 has the alternating current symbol marked, diagonally you have the other alternating terminal where the outputs of the transformer are connected. Then it has another terminal marked positive, diagonally the negative terminal are the rectified outputs.
