Automotive electricity
KIA Cerato / Spectra Flashing / Directional Lights SOLVED!
petit89
petit89
787
hace 6 años
hace 6 años
Good friends, I have a problem with my kia cerato / spectra 2008 and it is that the turn signal / turn signals on the right side have stopped working ... I already checked fuses, relays, bulbs and exchanged between them and it did not work .. searching the internet I found a case similar in which those on the left side failed ... it should be mentioned that it does not work or directional at the time of crossing or in emergency / caution light ... in the case I found mentions the user that there was an "isolated relay" and That was fixed by opening the cabin rifle, I disconnected it but I had the problem of not being able to remove these screws, can you tell me how to disassemble them completely? I did not force not to damage the component, any other suggestion regarding the failure is welcome ... Thank you
petit89
petit89
787
hace 6 años
hace 6 años
SOLVED ... (in case anyone else has the problem) After reviewing the basics: lines, spotlights, button. The problem that can be thought is a flasher or relay, the issue in this car (from this version) is that they do not come outside as we are used to, they are already integrated in the module at the top of the rifle, if you know someone who knows electronically and can disassemble the part to repair it excellent, if not, it is best to change it completely, it is not very expensive (used), I have changed it and the problem was solved at first. This information and solution was found by thoroughly investigating on the Internet in a similar or equal fault that users had. Regards
