I do not know what to do with the subject hugo, I see them, but in the free market
https://articulo.mercadolibre.com.ar/MLA-704076772-regulador-de-voltaje-tdelco-chevrolet-sonic-cruze-tracker-_JM
https://articulo.mercadolibre.com.mx/MLM-634327853-alternador-chevrolet-cruze-original-chevrolet-sonic-_JM
Hello, that alternator is not Valeo, it is a replacement for a Delco Remy alternator, that is not a problem, the issue is the regulator, the one you have is completely handled by the vehicle's computer, otherwise it could cause it to not work. What I would do in your case is to look for a regulator that does not work in an electrical workshop, to use it only as a brush holder, and place a regulator outside, type Nosso MEF 13 or whatever you want. If you do that, I tell you how to install it.
Yes, that is the idea, I once did that, using the coals, one to ground and the other at the exit of the regulator, and on the other side of the regulator contact, I imagine that this is the same, but I prefer you tell me that you know. I was going to use the same carbon carrier regulator only if this happened, what I imagined could not be placed sensibly by connecting it.
