Automotive electricity
Problems with the flashing lights and beacons
sebastian1111
hace 6 años
hace 6 años
Hello friends foristas, I do not have the beacon and winks flasher, I changed the flasher but it still does not work. What should I look to see what would be the problem? Thank you. Ah is a Renault 18 gtd.
laion2016
hace 6 años
hace 6 años
another possible cause may be; if the flasher is 4 terminals use negative, that is mass, you have to corroborate if in the plate (fuse holder / relays) the negative arrives in the middle terminal, sometimes it happens that this track deteriorates because of some overheating x.
hugodesalta
hugodesalta
2.450
hace 6 años
hace 6 años
You should first look at the fuses, although I don't think it's the problem, because they are different fuses for turns and for beacon. What should not work well, is the beacon key, since it is in the "no" position, it enables the turn signals.
