Automotive electricity
Problem with Ford Focus 1.6L Speedometer
DragOmar1
hace 6 años
hace 6 años
Goodnight everyone: Recently I was able to buy my first car. A Focus One Ambient 1.6 L. I am doing things to leave him 10 points. The problem that I cannot solve is that the Velocimeter does not work. PEEERO, the problem is not that it does not work, because if I change the 30A fuse it starts working. But it is about 2km (or less) and the fuse flies. Does anyone have any idea what it can be?
celentauro
celentauro
3.878
hace 6 años
I pass you a pdf link on the electrical wiring of the Focus, several models, I hope it works for you. If I find the electrical diagram I let you know.
https://josemaco.files.wordpress.com/2011/03/focus-dc-12-20051.pdf
celentauro
celentauro
3.878
hace 6 años
Put what years is the car to go to fixed shot.
DragOmar1
hace 6 años
Celen ..... Solved. Thanks for the diagram. The fuse controls among other things, the Lambda Probe, and this is the one that was short. Nothing to do with the sensor or anything like that. Disconnect it until you get the new and problem solved.
celentauro
celentauro
3.878
hace 6 años
Puff that good to find the fault. There is nothing more cumbersome than electrical problems in a car
celentauro
celentauro
3.878
hace 6 años
hace 6 años
I should get the diagram and see that ELEMENTS protects that 30A fuse. It is very amperage so it has to be more than lights. Apart from the tachometer is there anything else that doesn't work? If you have an airbag, will they not be disconnected?
DragOmar1
hace 6 años
Yes, I am trying to get it. The problem is that I was checking and found bridged cables to the speed sensor. What already is a problem.
celentauro
celentauro
3.878
hace 6 años
It is the bad thing about when people reach out to solve problems and not solve the problem, if not that complicates it more. It is a fuse to withstand a lot of power.
baron Mcpety
hace 6 años
hace 6 años
If the fuse blows on you. WELL that is short, doesn’t it tell you just that. A speed power cable is grounded.
DragOmar1
hace 6 años
I am sorry to disappoint your obvious answer but there is nothing short, the problem is that it has a bridged cable that is carrying more current than is due. I am tracking where it comes from and trying to see why they did it this way since I am not only having problems with the speedometer, but also with the central locking (which, when it reaches 10km closes, or should close the doors), apparently the Airbags as @celentauro says well and also something with the Gas team. They put a lot of hand.
baron Mcpety
hace 6 años
Look, a short is when a cable is altered, hacked, or in contact with another. What causes overheating, malfunction, burning of rifles. I obviously did not mean badly.
