Automotive electricity
kia alternator
chema
chema
52
hace 6 años
hace 6 años
good could you help me I have a KiA river alternator but it is loose with everything and cable and I don't know how to install it or know where the cables go I would appreciate the help
electrostorm
electrostorm
2.622
hace 6 años
hace 6 años
[url=/ver-adjunto/aHR0cHM6Ly9hZGp1bnRvcy55b3JlcGFyby5jb20vZGVmYXVsdC8wMDA0LzgwL1cgS0lBIFJJTy03NzU5NC5wZGy=]/imchta/atta/atta/atta/atta/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/atta/wind/wind/atta/wind/atta/wind/atta/wind/atta/wind/attach Check if this mitsubichi alternator is equal to your Kia river if it is equal to the L that is good from the board is the little sign that indicates battery the letter S ai voltage arrives when you open the power switch and the B indicates battery even the thick cable that reaches the alternator this diagram of the alternator is from a 2002 Kia Rio
chema
chema
52
hace 6 años
ah ok hand and if it is the same but the letter S the cable where it goes ??
electrostorm
electrostorm
2.622
hace 6 años
https://1drv.ms/b/s!AkDpIKcd6H2LlnMeqDBlaADqGVrO
I could not send you this diagram yesterday I hope it clears you more doubts friend
chema
chema
52
hace 6 años
thank you hand you work with eñectrp auto could you help me about a cable car of kia tengonel diagram and all complete but there are things that I don't understand.
electrostorm
electrostorm
2.622
hace 6 años
if they are the ones that are connected to the alternator tell me what is your problem to see if we can solve it between the two
electrostorm
electrostorm
2.622
hace 6 años
Tell me if your alternator is the same as the one in the photo you send and if not, send me a picture of your alternator that shows the part where the connector of the 2 cables S and L on the alternators has a letter S ai sele puts a cble that brings 12 volts from the power switch and the letter L ai arrives the cable that comes from the board leaves from the spotlight that when you turn on a battery on you have to locate these 2 wires is very easy with a test focus put it on battery negative and with the tip you feel the cable you open the swtchs and the bulb that indicates battery lights
