Automotive electricity
Electric motor problem
boris1989
hace 6 años
hace 6 años
Hello friends, I hope you can help me. What happens is that I have an alzavidrio engine that does not want to work, it is only when applying manual movement, it works for a while and it is stopped again as if it is stuck or locked that it is difficult to operate. It is a Chinese model and is visually in good condition to disassemble and check everything looks good but does not want to work. What can I do to repair it or what method should I follow to solve the problem? [Img] Boris. [/Img] [img]/js/ckeditor/plugins/attach/attach_25.png" alt="" /> 20190529_130729. jpg [3.03MB] 20190529_130722.jpg [3.31MB] 20190418_100049.jpg [2.95MB] 20190418_100021.jpg [4.29mb]
Alaen
Alaen
2.336
hace 6 años
For nothing, friend ... when you need we will be here, greetings and good luck ... ahh and an abrasion from Cuba.
boris1989
hace 6 años
✌ Thanks greetings from Chile ✌
Alaen
Alaen
2.336
hace 6 años
hace 6 años
HELLO..... The rotor seems to be fine .... the thinner where the coals make contact also although since we are passing blade or screwdriver with flat mouth between one and the other and sand well ... the coals are less good too, but it's worth cleaning them a little ... and finally the axles may wear where they flatten and he is lying on his side so it locks check everything ... grease well and Tell me
boris1989
hace 6 años
Thank you my friend, I will work on what you published and commented on.
boris1989
hace 6 años
Hello friend, thank you very much for your help, thanks to that I was able to repair the engine, now it is running at 100% and it looks like new.
