Automotive electricity
Turn on the battery light on the board
Carpintería.sergio.
hace 6 años
hace 6 años
Good day! Last night returning on the route I noticed that the low lights on the pavement varied in intensity! After a while he turned on the battery light for a while after turning it off and when it starts it turns on for a while after it goes off! My question is the following, I still have to do 300km to get back to my house! What problem can I have on the route? It is an ecosport 2008. Thank you for the contribution friends
ELEkTRÓN
ELEkTRÓN
2.042
hace 6 años
check that the terminals are not loose (for what you say that the warning light turns on and then it turns off it may be that or the loose alternator etc etc) start by checking the cables and terminals of the battery !!! As for the 300km you must do, I don't think it's a problem while the engine is running! then if you take the truck to the mechanic if you don't get up to it regards!!!
Carpintería.sergio.
hace 6 años
Hello the terminals are good and clean now the light turned on and does not turn off! Tomorrow I take the electrician and comment
Carpintería.sergio.
hace 6 años
Well group visit the electrician tested and effectively does not charge! Given that we were at 9am Saturday. I advise charging a battery and continue traveling to my trusted workshop. Because if you disassembled and did not get a replacement, you had to wait until Monday. I count that I had the truck loaded and of course during the day and without lights on, I arrived at bs.as. I did 270 km if problem tomorrow should allow me to reach a workshop!
ELEkTRÓN
ELEkTRÓN
2.042
hace 6 años
hace 6 años
Greenmaster
Greenmaster
2.849
hace 6 años
hace 6 años
If you are in a rainy environment it could be that the alternator belt skates with water otherwise it could be a loose or worn belt. If it is gasoline I recommend you check the alternator system before following the route because if you run out of alternator you stop.
Forzos
Forzos
620
hace 6 años
hace 6 años
Hi, can it be the battery or alternator voltage regulator
Carpintería.sergio.
hace 6 años
It was indeed the regulator! An isolation problem! He was able to repair the same track that is integrated and is already solved thanks
