Automotive electricity
dodge ram 2500 4x4 year 1999 in motion turns off NO BUS APPEARS
jesusledezma
hace 6 años
hace 6 años
I HAVE SOME TIME FIGHTING WITH THIS FAILURE, I WILL AT ANY SPEED OR PARKED THE TRUCK IS OFF, THE WORD DOES NOT BUS ON THE BOARD, IT HAS BEEN SCANNED AND TWO CODES, IAT AND TEMPERATURE SENSOR APPEAR, WHEN IT HAPPENS TO HIM TO THE HARNESS OF THE COMPUTER AND THE NEEDLES OF THE BOARD REACT AND COME ON AGAIN, BUT THE LAST TIME WAS NOT SO AND NOTE THAT THE COMPUTER WAS VERY HOT, SITUATION THAT I DID NOT HAVE ACCOUNTED ABOVE. BUT IT WAS SO HOT THAT IT WAS ALMOST IMPOSSIBLE TO TOUCH HER .... I AM FROM VENEZUELA AND THERE THE SITUATION WITH THE SPARE PARTS THIS EACH TIME, THANK YOU HEART ALL YOUR HELP, GOD BLESS YOU.
Dilker Carmona
hace 6 años
hace 6 años
Good afternoon, dear, in that case you must scan with an original scanner, most of the scanners give you preliminary information, the original makes more accurate diagnoses, I also live in Venezuela, and at one point I had a failure, send with scan a quality team and threw the error and (in my case) it was a fault in the TPS, "a fluctuating failure" In those cases, with the initial fault you had, the batteries must be disconnected and the connectors (harness and the module itself), the motor computer, the box, the bodywork, and the cluster must be sprayed with electronic contact cleaner. vibrations, dusts cause that, too. Right now with the fault you should check the relays, fissile, that are not burned, sulphated or reheated for any failure or modification in the original electrical system, the cars of the Chrysler group are very delicate x that, any modification of the electrical system, generate disturbances in The whole system, and if they are more automatic yet, they are jealous even with the sensors or mopar or mopar. Since the computer is so hot that nothing can be touched there something must happen internally, no that is not normal, with these electrical failures you have to be very outstanding because the cars can be short-circuited and even burn, I recommend the website www.zonaxj.com It is from here of Venezuela there you subscribe and you can put your case in the group, if you are in ccs the brothers of the forum will recommend you to do and in such case they will tell you of the excellent mechanics certified in chrysler, that may be in each city. success a hug
