When he is in contact he throws a spark, when I start anything and when I turn the key he throws another. I don't think the drum is because all it does is turn to pull a bone bolt, it has no wires or anything. I also didn't find a starter contactor or something
In contact, check the place where 12V arrives from the ignition key. You can put a small 12V lamp between that point and ground, so that it turns on when making contact. Then you start and the light must remain on. If the voltage is not lost, you must test the ignition sensor.
The technicians do not talk about "new" we talk about good because it has been tested, I have already asked customers for module and they have brought it to me new but bad, in their box ...
The truck also worked with that module. I had changed it because I thought that the fault I had before (for which the engine was disassembled) was produced by it.
