Automotive electricity
Where is the relay of the directional !?
Brayan Tello
hace 6 años
hace 6 años
Good, I wanted to know where is the relay of the directionals of a Pontiac grand am 2001 since I have the problem that the left directional flashes fast !?
linogonzalez
linogonzalez
2.331
hace 6 años
regularly when it blinks fast it is because you bring a molten focus
Brayan Tello
hace 6 años
What happens is that I already put a new spotlight on it and it keeps on blinking fast! ... I know if you should also change the directional and flashing lights of the left headlight! Could be?
Because the turn signals work well I know what problem is
Forzos
Forzos
620
hace 6 años
hace 6 años
Hello, have you placed new two lamps, both front and rear turn? Do all the lights work inside the optics both front and rear? I don't think it's a reley issue since it commands all the same. If you don't do it on the right side and you don't do it with the beacons, you would consider the problem with the lever or the wiring. However, it would not be wrong to remove the lever from its position and to bind the right side with the left to unload the piece.
Brayan Tello
hace 6 años
I just put the new spotlight forward ... You also have to put a new spotlight back?
Forzos
Forzos
620
hace 6 años
To rule out failures I would say yes, then continue with what I mentioned. It would also be necessary to see if it is not a problem of mass. When you place the left turn light, it does nothing abusively Did you try this with the low lights on and placing the turn light to see if other lights don't react?
