Automotive electricity
Fiat Uno 97 voltage regulator burns every 6 months.
a-gustavo
hace 6 años
hace 6 años
Hi. I have a fiat uno 97 which burns every 6 months the voltage regulator that is in the alternator. I don't know where to look for the fault anymore. I fixed the mass and it was fine, I took him to check the battery with the computer and they told me that it was fine and that the alternator worked very well ... 3 weeks later the regulator burns, I send 20 volts and the module On burned too. I would appreciate any help from now thank you very much.
Forzos
Forzos
620
hace 6 años
hace 6 años
Hello, what amperage is the battery that is placed? What brand of voltage regulator are you placing? Does the car have any attachments other than factory lighting or stereo?
a-gustavo
hace 6 años
Good morning Forces. First of all thanks for the help. The battery is 70 amp, the voltage regulator is "Nosso" and has a modern digital stereo that strikingly broke down ten days ago (it turned on alone and could no longer listen to radio or anything) the car has an LPG gas system installed from I have it, about four years.
Forzos
Forzos
620
hace 6 años
When was the digital stereo placed? Approximately. When I send the 20v the stereo was on? I would add one or two more masses to the car, either from the box to the chassis or some extra bolt. In the one it was always useful to have masses of more. With how much power does stereo work? The voltage regulator is a good brand, a Marelli would not be too much.
a-gustavo
hace 6 años
Hi Forces. I was very busy. The stereo was damaged before the car was damaged. I think it is a very good idea to add another mass. Today I will take them to check the donkey boot ... it seems heavy. Next week I will launch and comment on any developments. Thank you very much Forzos.
a-gustavo
hace 6 años
Hi Forces. The mechanic told me that the starter donkey was badly armed, that it had an extra washer and that that forced it more, which means a greater amount of amperage at start-up and that that could be slowly deteriorating the ignition. I will try to see what happens. Thank you.
Forzos
Forzos
620
hace 6 años
Hug and enjoy it
