Automotive electricity
Turn on high beams without turning off the low h4
Antonio Perez
hace 6 años
hace 6 años
Hi, how are you? I have a big doubt, I installed some retrofit projectors in my car, which have a h1 bulb in my case I used h1 led. The connection of my car is H4 and for obvious reasons when I turn on the high beams, the lows are turned off, how can I do that when I turn on the highs, I keep the lows on, so that when I activate the highs I activate the projector magnifying glass while I keep the lights connected in lows on. I hope to explain my doubt well, greetings !!!
JoseOrtiz
JoseOrtiz
1.274
hace 6 años
It is assumed that the high light does the same work as the low and that is why they go out, or do you not have bulbs for high so you will use the magnifying glass that you say?
Antonio Perez
hace 6 años
That's right, I have only one bulb, that when I turn on low I only have the light from the bulb. The moment I turn on the high light, I activate the magnifying glass but at the same time keep the light bulb on
JoseOrtiz
JoseOrtiz
1.274
hace 6 años
hace 6 años
You should invest rather in fixing the original lights instead of doing those things but good, locate the relays that command the high and low lights, in each place the cable with the signal that activates them, already knowing which ones are placed a diode between these two cables with the cathode towards which the low light commands.
Antonio Perez
hace 6 años
Thank you very much for your help!
JoseOrtiz
JoseOrtiz
1.274
hace 6 años
To the estimated order, greetings ...
