Automotive electricity
Fiat uno way attractive 1.4 8v 2010
Daamiiann
hace 6 años
hace 6 años
Good morning . I wanted to know if someone can help me, it turns out that my fiat stopped starting from one moment to the next and started to turn on the "check engine" light. When starting, the engine turns but does not start. Check if the pump worked and it's ok, then I tried if it sparkled to realize that it was not like that. I checked the ckp sensor and it works, check the rpm sensor and it works, new battery, spark plug wires and new spark plugs. I opted to send it to scan and figured that the 4 ignition coils were missing, when sending it to test they told me it worked fine, as a last option I checked the central rifle (located in the engine) and only found 1 blown fuse of 20A, in the manual figure that belongs to the socket and cigarette lighter so discard that may be the cause of the problem, also in moments I will put a new fuse. In summary. Does anyone have any idea what else could I get to try? ... Thank you very much!
MJGTSAS
MJGTSAS
4.613
hace 6 años
hace 6 años
Good afternoon, I verify that the anti-theft system is not blocked.
Daamiiann
hace 6 años
Mjgrsas First of all, I thank you for responding. And forgive the ignorance but how could I tell if the anti-theft system is activated?
MJGTSAS
MJGTSAS
4.613
hace 6 años
first to know if your vehicle has the system verify it in the auto manual as a feature.
Daamiiann
hace 6 años
Solved !! . at the end it came from that side ... It had a secondary alarm that had been added to it and it was definitely short. thank you !!!!
MJGTSAS
MJGTSAS
4.613
hace 6 años
I'm glad you solved your iconvrnirnte. Cordial greetings
