hace 6 años
How's it going, good evening, friends?
I commented that I came to repair a Jetta Mod. 2013 for air conditioning, the fault was high pressure sensor with short to ground, replace the 5 amp fuse that feeds it and ready, it works. Days later he returns with the same fault. Place a new sensor as a test and replace the fuse again, one day running and the fault repeated. This time, check to see where the access allowed me the power supply line of the sensor without finding a visible problem, so I decided to enable a new power supply line with a new fuse up to the sensor and it's working. Now the problem is that I did not notice that the right front directional light stays on since the car is started, when the car is turned off it stays on for about ten seconds and turns off, but again when the ignition is turned on that light comes on . All others work correctly (reverse light, headlights, brake lights, front and rear left turn signal, right rear turn signal) only the light Right front turn signal stays on, does not flash or goes off while the car is moving. when the central locking device is in place, all the lights come on for a moment and then go off, except for about ten seconds and then goes out. I do not have much experience with lights.
Someone had a similar problem that could help me, I would appreciate it.
