Televisores LCD - LED
LG led TV without audio output
Televisor LG 32lj510b
maurikorn
Hi. Somebody help me. I bought a led tv brand LG 32 "model 32LH510b and I find that it does not have any audio out jacks .. Digital Ni .. Ni Rca Ni jack 3.5 .. NOTHING. Previously I used a home cinema with a RCA card. Now there is no way. And my account is as follows. I have a chromecast 2 which is the one that interests me to hear in the home. It is connected via hdmi. I would like to be able to listen to whatever I send to the TV but I am conditioned. Thank you very much and greetings. I leave an image. 20170828_085902.jpg [2.62MB]
franciscovallarta
it is not very clear what you want, if you want to listen to the tv on the amplifier, whether your amplifier has hdmi input or not, or not explain well. look there are different devices in the market for what you want, like an hdmi converter with hdmi and rca output so you could send the audio signal to the amplifier, an example the following. device, everything is question that you approach the electronics store, you can also remove the audio from the TV with another device from the internal horn cables, but this can only be done by a technician .... greetings.
maurikorn
What I want is to listen to the TV in the home theater. But I see it limited given that the led has no audio output. They are all inputs. And if there is an artifact to achieve it I wonder if there is something like to be able to listen to the chromecast by sending the video to the led and the audio to the home theater
maurikorn
Sii! The device you tell me is the best quick fix. Since to be able to amplify the internal speakers of the TV is more risky and also is new the LED. Thank you very much for the tip.
