Monitores
*Samsung SyncMaster 793s imagen con colores cambiados
Monitor CRT Samsung Syncmaster 793s
acuario54
hace 19 años
hace 19 años
Hola amigos: Me llegó este monitor que tiene solo 3 meses de uso con el siguiente problema. Cuando arranca el sistema operativo llamese windows XP o cualquier windows, cuanda aparece el fondo negro, las letras que debieran aparecer en blanco, aparecen en color violeta. Por supuesto ya dentro de windows los colores están todos cambiados. Me parece un típico problema de que los drivers o transistores que comandan los canales de colores están mal. Pero resulta que este monitor no dispone de drivers individuales para cada color y solo usa en la plaqueta del cañón del tubo dos integrados. 1) LM2470TA de 9 patas en formato vertical The LM2470 is an integrated high voltage CRT driver circuit designed for use in color monitor applications. The IC contains three high input impedance, wide band amplifiers which directly drive the RGB cathodes of a CRT. Each channel has its gain internally set to -27 and can drive CRT capacitive loads as well as resistive loads present in other applications, limited only by the package’s power dissipation.The IC is packaged in an industry standard 9-lead TO-220 molded plastic power package. See the Thermal Considerations section for more information. 2) LM1236 DEM The LM1236 pre-amp is an integrated CMOS CRT preamp.It has an I2C compatible interface which allows control of all the parameters necessary to directly setup and adjust the gain and contrast in the CRT display. Brightness and bias can be controlled through the DAC outputs, which are well matched to the LM2479 and LM2480 integrated bias clamp ICs. The LM1236 preamp is also designed to be compatible with the LM246x high gain driver family.Black level clamping of the video signal is carried out directly on the AC coupled input signal into the high impedance preamplifier input, thus eliminating the need for additional clamp capacitors. Horizontal and vertical blanking of the outputs is provided. Vertical blanking is optional and its duration is register programmable.The IC is packaged in an industry standard 24-lead DIP molded plastic package. CONSULTA: 1) ¿Podrá ser el Integrado LM1236 el causante de los problemas???????? 2) ¿Le pasó a alguien lo mismo y si así fue, cómo solucionó el problema? 2) ¿Alguien dispone del Circuito de este monitor ya que en la WEB no lo encuentro por ningún lado? 3) ¿Alguien dispone del Manual de Servicio Técnico de este monitor ya que es el mismo caso anterior NO encuentro absolutamente nada sobre este monitor? Desde ya muchas gracias por la posible ayuda. Peter Serpico :o Salta - Argentina peterserpico@arnet.com.ar
acuario54
hace 19 años
hace 19 años
Hola: Agradezco la respuesta sobre este tema y les comento cual fue en realidad el problema y cuál fue la solución. Problema: Todo sale en color violeta El cable de video en su conector que va a la placa de video en la pc tiene en su interior cortado el cable que va al cátodo verde. Solución: Se cortó el cable con el conector defectuoso y se puso un conector DB15 nuevo. Gracias por responder Peter Serpico :lol: Salta - Argentina peterserpico@arnet.com.ar
tecnoservice
tecnoservice
1.329
hace 19 años
hace 19 años
Me alegra que hayas resuelto tu problema,pero si te fijas en el paso 5 que te indique se trataba de verificar el estado del cable y eso era lo que te fallaba y me valoraste " [color=green:c5cb76a4e9]Asiste a la Solucion [/color:c5cb76a4e9]" y debes valorar como " [color=green:c5cb76a4e9]SOLUCION[/color:c5cb76a4e9] ".
acuario54
hace 19 años
hace 19 años
Tienes mucha razón: Yo pensé que asiste a la solución era lo que correspondía pero lo corecto es SOLUCION. De todas maneras gracias por responder y ayudar. Peter Serpico :oops: Salta - Argentina peterserpico@arnet.com.ar
tecnoservice
tecnoservice
1.329
hace 19 años
hace 19 años
Tu problema puede ser resuelta siguiendo los siguientes pasos: 1) Probando con otra pantalla para asi saber si es pantalla agotada o no 2) interconectar el monitor por una interface llamado Softjig por medio de un software a la pc a fin de poder entrar en el modo de servicio del monitor y asi ajustar los colores 3) Rectificar la placa del TRC reemplazando los electoliticos y resoldando toda la placa del TRC 4) Verifica los voltajes en cada catodo de cada color KR KG KB 5) Verifica el estado del cable de video el que va a la pc que pueda que tenga uno de los cables roto y te falte un color para que se vea bien 6) Y por ultimo si con todo lo anterior no solucionas la falla pues ahi reemplazas el integrado LM1236. Comenta los resultados y suerte.No olvides VALORAR amigo para que te pueda seguir ayudando.
