Celulares
Drenaje de bateria Galaxy S5
Jesús Marroquín
Hola, hace unos meses compré un samsung s5, venía con un error en el sistema operativo y cambié el firmware, todo bien hasta aquí, pero el único problema es un detalle con la batería, se consume muy rápido, en cosa de 4-5 horas llega de 100% a 30%, el uso que le doy es regular, contestar mensajes y llamadas pero nada en exceso. Compré una batería nueva creyendo que era éso y resultó que se agota mucho más rápido, no se que pueda ser, muchas gracias
jamessusan104
I have a comparative issue. In the event that you have Android version 5.1.1, numerous clients have encountered extreme battery loss contrasted with before versions. Along these lines, as I would like to think, downgrade to a prior programming form and you may see some unobtrusive contrasts. can someone do my assignment - BuyAssignment.com
Jesús Marroquín
The android version is 6.0.1, but I think that is the problem, I suppose the version is for another country, the version have problems. Whatever it is, I will download an earlier version.
AndreasParker
If you encountered this problem then you have to do these steps: [list] [*]Firstly, restore your previous android version that will be compatible with your S5 [*]Secondly, you have to go to settings>Applications>background app services here you can stop those services that you want to not use. [*]If the problem is consistent then you have to buy the original battery of S5. [/list] Regards, Andreas Jones Resume Writer-ResumeWritingServicesUS
Jesús Marroquín
Hello, I still have the cell phone, although only as a replacement.
In the past, it was restored to its original version and the proposed process was performed, in addition an original battery was purchased, however the problem persisted.
Anyway, thank you very much for the contribution, I appreciate it.
