Celulares
Burned load center
angelfalcon38
Good afternoon forum, the problem is the following I put to charge an iphone 4 and it seems that I burned the charging system since the comb looks somewhat smoky, the phone turns on and off ok but no longer charges or connects to the computer , is it enough to change the charging system for a new one?
fernando perez
not bro to check if some fuse or coil did not go too, greetings or see the area where it is smoked and check with the multimeter if they are in good condition lps components but then it would only change the center of charge
angelfalcon38
Thanks for the help.
already change the load system and now load, now I will try to connect it by usb, update itunes itunes and check if everything works correctly
