Celulares
S133 Meid 00000000000
Enriquesoftware
S133 movilnet después de hacerle software quedo en Meid 00000000 ..... HUAWEI Ku no reconoce el puerto ..... Meid Escrib Fail.....
Terarti
Terarti
52
Respalda el esn con cdma workshop de la siguiente manera, abres CdmaWorkshop y conectas el Tlf seleccionas el puerto com, vas a Pestaña Memory, Read NvItems y lo guardas, y a esa copia le cambias solo la celda 1943 (0x0797) que quedara asi 1943 (0x0797) - Inactive item en su normalidad deberia aparecer de la siguiente manera o similar (ojo hago un ejemplo) 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Un Total de 8 Columnas y 16 filas de ceros (0) ya que la Fila (1943) se encuentra corructa o dañada por el flasheo realizado, Teniendo la Fila --- > 1943 (0x0797) - Inactive item, entramos en la copia y modificaremos toda la celda 1943 y colocas 1943 (0x0797) OK y el meid quedaria algo asi: ejmplo: 1943 (0x0797) - OK 11 22 33 44 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 El meid del equipo al reves, de dos en dos y guardas, luego abres Huawei Ku y conectas el tlf le das click al Boton FTM On esperas que reinicie en modo FTM Abren cdmaworshop pestaña Memory y le das Write a NvItems Seleccionan el Archivo que hemos modificado y esperas, cierras el programa aceptas el msj y listo, luego conectas otra vez y colocas el ftm off... suerte recuerda valorar
Terarti
Terarti
52
copia y pega esto en dicha casilla, ojo solo modifica los numeros, si el meid es 0A000025638954 lo colocas al reves de dos en dos, ejemplo: 1943 (0x0797) - OK 54 89 63 25 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Enriquesoftware
[quote="Terarti"]copia y pega esto en dicha casilla, ojo solo modifica los numeros, si el meid es 0A000025638954 lo colocas al reves de dos en dos, ejemplo: 1943 (0x0797) - OK 54 89 63 25 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00[/quote] la casilla 1943 esta vacia completamente debo llenarla completa supongo ?
Enriquesoftware
[quote="Terarti"]copia y pega esto en dicha casilla, ojo solo modifica los numeros, si el meid es 0A000025638954 lo colocas al reves de dos en dos, ejemplo: 1943 (0x0797) - OK 54 89 63 25 00 00 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00[/quote] el procedimiento se realiza correctamente pero me sigue apareciendo el meid 0000000[/b]
Terarti
Terarti
52
vuelvelo a flashear y claro, copia y pega esa casilla completa y solo le modificas los ocho digitos al principio con el meid que trae la etiqueta del cel, luego con cdma workshop reparas en nv item write
Enriquesoftware
[quote="Terarti"]vuelvelo a flashear y claro, copia y pega esa casilla completa y solo le modificas los ocho digitos al principio con el meid que trae la etiqueta del cel, luego con cdma workshop reparas en nv item write[/quote] No Funciono mano, utilice otro metodo con efs pro y huawei ku y esta ok 👍
