Tablets
Alcatel One Touch P310a Urgent Help Problem
Celular alcatel DB
Celular alcatel DB
antonioguata
Hello friends of I repair I have a problem with this table which presents a series of distortions or stripes in the screen that are removed as they are put on sometimes looks excellent others appears what in the photos and placed I would like to help me since rum is not obtained from this and I would like by means of CWM to install the rom through the sd if it is rum problem or what problem will it be because of virus or I hope you can help me, I would really appreciate your advice and help thanks
julio 23
julio 23
2.353
Hello friend, the first thing I would do is open it and see if the flex of the panatalla is well inserted, if it is .. see that it is well pressed in the flex connector, because rom failure fails there would be few possibilities
Cheers
Franco salusso
friend, that seems flex problem making bad contact ..
TeddyGhant
Hello there is the link of the rom https://forum.xda-developers.com/android/general/mt8312-unofficial-alcatel-onetouch-pop-t3011278 but I agree with the others it sounds like a Display problem that may be failing the same or the flex or be loose, the first thing you should do is open it check the connector and take it out and put it back to the flex making sure you connect it correctly to the line of demarcation that brings the flex and in passing check that it is not marked somewhere regards
antonioguata
hello teddyghant thanks for your contribution really the question is that it does not seem to be a problem of the flex or screen since it became slow spuer birds stay stuck in the logo other times in frozen or stuck and in other cases when I try to unlock it it takes to do it for I say that it is not a problem of the screen since it would not be slow or throw problems like operating system even reboots in some cases
antonioguata
friends can someone guide me in the installation of the rum through the sd since the loading pin is not very good to say and I would like to install the rom through the sd
