Tablets
tablet does not turn on, quo blaze 7 3g
Johanfma
tablet quo blaze 7 3g does not turn on it was working and let it turn on what will it be?
Salvador perez maximo
Hello, check the feeder and comment merry Christmas and receive best regards ok friend.
nicolash2009
If you remove the cover and you have a soldering iron, you could desolder the battery cables, charge it with a source or if not, a charger without a tab, connect the positive of the charger with the positive of the battery and the same with the negatives. ... you expect it to charge for a while, you measure with a multimeter that the battery has 3.7 volts, you re-solder the battery to the board and there it could turn on ... if it doesn't charge, it's the battery, if it charges and doesn't turn on , it could be the power button or the power management ic
