Tablets
Argom Tech T9500 Tablet Battery Change ....
methos
methos
3.483
hace 6 años
hace 6 años
Hello! Good day! Does anyone own the technical manual of this tablet? It seems that the battery reached the end of its useful life and it is necessary to replace it, but I do not have the technical manual to know how to disassemble it to make the replacement ... The fact is that apparently it has only 7% battery, I put it to charge with its original charger and after a minute it marks me 95% charge, I disconnect it, not even 2 minutes pass and it marks me that it has between 5 and 7% charge ... Salu2! : D
elmeneao
elmeneao
115
hace 6 años
hace 6 años
Wuenas! put a 6000mAh lithium polymer battery! Open the back cover and desolder the battery contacts if it is welded, and weld the new one! or if it goes in a connector, you disconnect it and put the new one and go! anything warns! don't forget to rate!
methos
methos
3.483
hace 6 años
Thank you! I'm going to find a spare battery of those mAh !!
elmeneao
elmeneao
115
hace 6 años
Thanks for rating! I'm glad you could solve it! Regards!
Salvador perez maximo
hace 6 años
hace 6 años
https://www.manualslib.com/manual/986175/Argom-Tech-T9500.html
hace 6 años
fence man there is his manual but I can not find the battery that carries greetings oki.
methos
methos
3.483
hace 6 años
Thank you! I found a video of how to open and change the battery to Argom Tech tablets:
https://youtu.be/q6ILdMAzrdQ
methos
methos
3.483
hace 6 años
Great thanks!
