Ipads
Ipod 4th generation lights flashing apple logo
AFICIONELECTRONICO
Hello Friends of the forum, I have in service a fourth generation Ipod (A1367 model) which the client told me that the battery discharges very fast, apparently I take it off the whole screen with a pick, and he referred it to me, now I see that the Apple logo appears intermittently when I connect the cable to charge it, and on certain occasions the battery appeared showing that it was charging, but currently only the logo appears intermittent, does this have reference to the battery or is it another detail apart?
pavul
pavul
12
I had something similar with an ipad 4 generation, what I had to do was replace the battery with a new one and that worked, the problem was that when I turned it on or charged it, the ipad was restarted, also if I wanted to restore it with iTunes not You could, when changing the battery and it worked well, try that first.
Salvador perez maximo
https://support.apple.com/es-co/HT204688
AFICIONELECTRONICO
Thank you, Colleague Salvador perez maximo, the information is very useful. Greetings!
