Alarmas
Error GSM en PCS250 PARADOX
Ache
Ache
2
Hello, my query is the following, I bought a Megallan 5050 alarm, a voice module VDMP3 and I have punched it on the PCS250 with SIM card Vodafone for GSM, NO GPRS, as the VDMP3 I turned on a red led and the led the GPRS PCS lights up green and the GSM off, I make the call from my cell phone and it rings several times and it hangs, I have downloaded the version 3.0 to 2.13 because I recommend a friend who was the most stable when it happened this with the PCS, even so, it does not work, what am I doing wrong? The screen is the TM50, in case it has something to do, I have 4 wired and 1 wireless, I need a solution as soon as possible, since next week has to be operative housing, come holiday renters, thanks a greeting to rmonch
redo
redo
7.086
Do you have a pcs250 or pcs250g?
redo
redo
7.086
The v3 I think does not work with vdm3.
redo
redo
7.086
have you connected the pcs250 to the ebus connector on the board?
Ache
Ache
2
Hi redo
It is a psc250 and it is connected to the Ebus of the plate
redo
redo
7.086
apart from the problem the vdmp3, if you make an alarm jump the gsm calls you? the gsm works
Ache
Ache
2
If I make an alarm jump, the gsm does not notify me, but if I call the alarm number it sounds a few tones and hangs
redo
redo
7.086
watch the video of the companion asmodeo You called where you bought it ,? the pcs250 v3 i think it is not compatible with vdmp3
Ache
Ache
2
Hi Redo, VDMP3 in version 3.0 is not compatible, I downloaded it to 2.13, still not ok, I talked to the distributor and they do not know what it can be, we have done tests and tests, in the end I will choose to put a transparent and return the pcs250, I know the problem is not the Paradox product distributor, but Paradox itself, do not go very well for certain specific combinations, or should I learn more, I think both, in fan, if anyone else can suggest me a proposal, I will take it as water from May, I have two days to solve it or I will change pcs
Ache
Ache
2
You could pass the BabyWare that you use, because in mine there are lines that do not appear to me, I have the v2.9.9 and if possible the In-Field Paradox, I have the v3.9.33
redo
redo
7.086
Descargas paradox aqui
Ache
Ache
2
Thanks Redo, I already work, updating some things and this operative, thank you very much redo, greetings crack
redo
redo
7.086
it would be interesting to summarize that you have finally modified, for example. What firmware did you use?
