Refrigeradores
pipe capacities
uli1311
hello how am I repairing a horizontal freezer which I will change the tubing of the evaporator that is 5/16 and I want to know if it affects that a 1/4 tube is not if it affects in the pressure or that prevents it to freeze less if they could advise, they would appreciate it
John People (Juan pueblo)
Hi, evaporator, condenser, capillary ,, and motor compressor are a system and are dimensioned proportionally to work interrelated, any changes can affect the performance of the same, if the evaporator is 5/16 you must put the same diameter, in addition to the length, and also the length and caliber of the capillary, greetings.
uli1311
if in fact already change the tube by the original and then really if there was a big change of pressure and he raised the working ampere of the compressor pot today I leave it working and tomorrow I will see how it works, and I wonder what it depends on you to lower more the temperature if I wanted to lower the temperature even more I need an intensive course of jejej pressures with relation to gas but tomorrow I tell you how my refrigerator works since I also made his new box and then if it will be like new
It is to be expected until tomorrow, until the system stabilizes, the gas injects and gives time of waiting, it is possible that it improves
rubensiño
rubensiño
22.830
clear qeu affected with 1/4 pipe does not drop to -15 degrees luck
4.52
(63)
Elkin Fernández
Agustín Belen
